1 vote
CLIENT REQUEST
When installing the application through PatchMyPC (or any system-level installation method such as Intune/Company Portal), the setup runs under System privileges. In this context, data sources cannot be added because they require access to user-specific folders. As a result, the installation completes, but the data source is not created.
Currently, data sources must be created in a user-level context, which prevents automated deployment tools from adding them during installation.
The client would like to have the possibility to add multiple Data Sources using a PowerShell Script to support the addition of multiple data sources with the script.
Maxim Robert
Hi, we are currently working on an improved version of the custom installation process, which should address this issue and make everything work properly. This update is planned for release in the near future.
Thank you for your patience!
Sébastien Aubin
Product manager - Password Management
