Better feedback when not able to authenticate
1 vote
I have spent the better part of 2 days troubleshooting an issue where I could not retrieve users or vaults on a server while these queries worked on another one. Eventually I found out the Application Identity I used had IP restrictions implemented.
When running the following to authenticate I got the following response (I used the -AsLegacyResponse to get more feedback during testing).
PS> New-DSSession -BaseUri $Uri -Credential $Credential -AsApplication -AsLegacyResponse
DetailedErrorMessage ErrorMessage IsSuccess                Result
                                       True               Success
Though in fact I was not authenticated due to the IP restriction. Performing a follow-up query thus yielded the following result.
PS> Get-DSVault -All -AsLegacyResponse
                                      False WebApiRedirectToLogin
After finally finding the solution for my issue, I noticed I actually got a faint hint about not being authenticated when using verbose logging.
Without IP restrictions in place the following will happen.
PS> New-DSSession -BaseUri $Uri -Credential $Credential -AsApplication -Verbose -AsLegacyResponse
VERBOSE: [New-DSSession] Beginning...
VERBOSE: [New-DSSession] Server version: 2025.3.5.0
VERBOSE: [New-DSSession] Authenticating as <redacted>
VERBOSE: [New-DSSession] Login as an application
VERBOSE: [New-DSSession] End
With IP restrictions the following will.
As you can see there is an empty line in the second response, which is the only indication authentication actually failed.
While troubleshooting I have also checked $global:DSSessionToken as well to see if I was authenticated. This variable has been filled even when failing to authenticate.
Could you add better feedback about failing the authentication? There is no need to hint towards IP restrictions as to now give attackers a clue. But at least let me know authentication has failed, since now I have been looking into the DSSessionToken not being passed onto subsequent requests.
Also please don't fill the DSSessionToken if there is no session.
All Comments (1)
Hello @reinleen,
We've opened a ticket to better indicate when there's an authentication failure with this cmdlet. We'll keep you updated.
Christian
