PowerShell - Get-DSEntry does not returne on invalid GUID
A fix for this issue has been implemented in version 2026.2.1
Implemented
When I run the command Get-DSEntry -All without passing the VaultID parameter I am asked for the VaultID as expected.
If I pass an empty string, or any other text which isn't a guid I keep getting prompted for the VaultID. I would expect the cmdlet to throw me an error and not keep asking indefinitely. Now I only have 2 options to get out of this loop:
  • Closing the terminal
  • Generate a GUID using the New-Guid cmdlet and passing this random GUID.
If I use the second option (passing the random GUID) I get an error not related to cmdlet, namely: Get-DSFolders: Unexpected exception
All Comments (5)
Hello @reinleen,
To stop the prompting loop, Ctrl+C should work.
I agree that this error isn't very descriptive; we'll look into it.
Christian
Ctrl + C works in pwsh indeed, but not in an IDE like VS Code (might also just be my configuration, but I don't have this issue with other cmdlets).
Hello @reinleen,
We weren't able to reproduce the prompt issue on our end; Ctrl+C behaved normally in VS Code as well as PowerShell. If the problem persists on your side, it may be environment-specific as you say. If you continue to run into this, feel free to share any additional details and we'll be happy to take another look.
Christian
Thanks for the clarification. Then it must be me with the Ctrl + C.
Still glad you will be looking into a more graceful return since Ctrl + C won't be a very useful solution to implement in a non-interactive script.
Hello @reinleen,
Version 2026.2.1 of the Devolutions.PowerShell module introduces an improvement to the 'Unexpected exception' issue raised in this thread. The affected cmdlets should now instead raise a more descriptive error, mentioning that the provided vault ID may not be valid.
Feel free to reach out if you have further questions or comments.
Christian
