Compatability Issue with MgGraph Module
Hi Devolution Team,
there is an issue when connecting to MgGraph, not sure that is something you have to fix or the Graph Module Team...
If the Microsoft.Graph.Authentication module is loaded (via require or import-module) before Devolutions.Powershell the connection to MgGraph fails with the following error:
Method not found: 'System.Threading.Tasks.Task`1<Azure.Identity.AuthenticationRecord> Azure.Identity.InteractiveBrowserCredential.AuthenticateAsync(Azure.Core.TokenRequestContext, System.Threading.CancellationToken)'
If you switch the order of module loading (Devolutions.Powershell before Microsoft.Graph.. then it works for some reason)
Tested with:
Powershell 7.5.3
Devolutions.Powershell 2025.3.0
Microsoft.Graph 2.31.0
a MSSQL Datasource
RDM Version 2025.3.16.0 (i don't think this has any effect)
How to reproduce:
Import-Module Microsoft.Graph.Authentication
Import-Module Devolutions.PowerShell
$Datasourcename = "XYXY" #Replace with your DS
$datasource = Get-RDMDataSource -Name $Datasourcename
Set-RDMCurrentDataSource -DataSource $datasource
Connect-MgGraph -NoWelcome
I also have attached a little script which outputs the loaded DLL's.
I think it has something to do with one of the Azure...dll's, but that could be a "red herring".
BR,
Stefan / CryoRig
All Comments (5)
Hello cryorig,
Thank you for reaching out to the Devolutions support team.
This is a known behaviour from the MgGraph module.
They also mentioned connecting to the graph before importing another module, such as AZ.
Patrick Ouimet
Hi Patrick,
oh ok good to know!
do you have a link where this is mentioned? a quick search didn't really give me anything "official" just multiple users with thze same or similar issue
BR,
Cryorig
Hello Cryorig,
This is on this page under the description.
https://learn.microsoft.com/en-us/powershell/module/microsoft.graph.authentication/connect-mggraph
Here is what is mentioned:
You must invoke Connect-MgGraph before any commands that access Microsoft Graph. This cmdlet gets the access token using the Microsoft Authentication Library
Patrick Ouimet
Hi Patrick, sorry for the delay in response.
i don't think that this is the same problem / issue...
Your quote is about how one needs to use connect-mggraph before any other mggraph command, which makes sense.
I also read through the page you linked and there is no mention about a specific order how non Graph modules like AZ have to be loaded...
If you read my original post, my issue is when i load the Graph Module BEFORE Devolutions.Powershell, then the graph connection does not work! (see the error from my first post)
it works when i turn the module load order around, which is the opposite of what you stated and also what makes me think that we are not on the same page regarding my issue.
BR,
CryoRig
Hello cryorig,
Thank you for this feedback.
In this case, I suggest connecting right after importing your module like this:
$Datasourcename = "SQL" #Replace with your DS
Patrick Ouimet
