Create file explorer entry type in vault
1 vote
I'd like the ability to open a link to our servers directly from the password vault via file explorer.
So i can link a vault to the project folder related to it.
I understand that the "file explorer entry type" is already available in RDM, but not in the HUB.
All Comments (7)
Just to be sure, do you want to be able to open file exporer entry types in the web instead of RDM?
Have a good day!
Maxime Morin
Hi Maxime,
That's correct. I don't use RDM, but i use the devolutions HUB / WORKSPACE APP.
And there the file explorer entry type does not exist.
Any feedback to this??
Hello Anders,
To clarify your request, would opening a direct link to a local or network file path (for example: C:\Folder or \\server\share) in the operating system’s file explorer be sufficient for your needs?
In RDM, the File Explorer entry type opens the folder as an embedded session, but this is not something we plan to replicate in Hub. Instead, we would be looking at a simpler option where clicking the path would open it directly in the OS file explorer.
Would this approach meet your requirements?
Sébastien Aubin
Product manager - Password Management
Hi Sébastien,
Yes, that solution sounds very promising!
Excellent, I will create a ticket to implement this feature in our web client and Workspace apps, including mobile, desktop, and the browser extension.
Sébastien Aubin
Thanks Sébastien, sounds great!
