Open connection button greyed out in Web UI
The open connection button is completely greyed out for any connection in the WebUI. There is a gateway farm configured, and all users and vaults have been assigned. Connections launch fine via the gateway with RDM, but the button in the WebUI is greyed out. The hub account has less than 5 users, which I think means there is no licensing requirement in order to use gateway functionality. Have tried configuring the gateway settings explicitly on the entry as well as using inheritance, but that did not fix it.
Not sure how to troubleshoot further?
Thanks
Joe
Could you confirm that your Gateway Product license has been assigned to the Users?
https://docs.devolutions.net/hub/web-interface/administration/management/licenses/register-product-licenses/assign-product-licenses/
Let me know,
Samuel Dery
Let me know,
@Samuel Dery
Hi Samuel,
As I mentioned, there are fewer than 5 users. Is gateway entitlement not free at that qty as per https://blog.devolutions.net/2024/08/spotlight-on-web-based-rdp-ard-ssh-in-devolutions-server-and-hub/ ? There are no gateway licences listed to assign, just Rdm and Hub which have allready been assigned to each user.
Joe
Thank you for your reply,
I see, previously there was a Devolutions Gateway (Free) license for 5 users present under "Administration" -> "Licenses", but upon looking into this, it seems that is no longer the case with our new licensing model.
I have reached out to you in a Private message regarding this,
Samuel Dery
