Connections through Devolutions Gateway not working
A fix for this issue has been implemented in version 2025.3.0.8
Implemented
I'm running RDM 2025.2.1.4 on Debian 13 Trixie with everything up to date.
When I try to connect to a resource that is configured to use Devolutions Gateway, I click on Open Session, and nothing at all happens. There is no error message, and no changes to the user interface at all.
If I try to connect to a resource that is not configured for Devolutions Gateway, it works as expected.
These resources all work normally in the Windows version of Devolutions Gateway. If I go to https://gateway:7171/jet/health, it reports alive and healthy. The TLS certificate on the gateway is current and trusted.
I can't find any logs from RDM to tell me what's going on. Does anyone have any insight? Thanks!
All Comments (2)
Hello Flowerss,
Thank you for reaching out to our forum. I can confirm that in RDM 2025 Linux versions connected to Hub Business, the Open Session button does not function when a Devolutions Gateway is bound to it. Our development team is currently working on a fix.
As a workaround, I suggest downgrading your RDM to version 2024.3.2.13, where this functionality is working.
I will inform you as soon as the fix is deployed.
Thank you for your understanding.
Michel Audi
This issue has been resolved, and the fix is available in the latest release of RDM (2025.3.0.8).
Please note that a database upgrade is required if you use SQL Server as your datasource.
Please consult this article prior to perform the upgrade
https://docs.devolutions.net/rdm/windows/installation/database-upgrade/
Please let us know if you are still encountering any issues or if this works as expected.
Maxim Robert
Closed
