Backlog
Clipboard issue on RDP
I'm experiencing an issue with my clipboard.
Initially, it works when I use it within an RDP session. However, as soon as I establish an SSH connection to a Linux server, the clipboard functions on the SSH session but stops working on the RDP sessions.
To get it working again, I have to restart the entire application.
My OS is Debian 13 (Trixie), RDM Version 2025.2.0.8, KDE Wayland. I'm encountering the same problem on Fedora 42 KDE and Ubuntu LTS 24.04.
All Comments (6)
Thank you for reaching out and for providing all the details—much appreciated.
So far, I haven’t been able to reproduce the issue on my end. To better understand what might be happening, could you please clarify your workflow? For example, are you using the copy/paste buttons in the RDM interface, or relying on keyboard shortcuts?
Also, if possible, could you share a short screen recording showing the issue? You can send it to us via direct message—this would really help us investigate further.
Looking forward to your reply!
Stephan
I made a video that I sent to you via private message.
This issue occurs with keyboard shortcuts (Ctrl+C, Ctrl+V) as well as with mouse clicks and the context menu.
Antoine
Hello Antoine,
Apologies for the delayed response.
I was able to reproduce the behavior you described and have created an internal ticket with our development team to address it. I’ll keep you updated here as soon as we have more information to share.
Stephan
Hello Stephan,
I'm glad to see your message and know you're on it.
Keep me updated, and if needed, I'm available to run tests.
Antoine
This is great. I've been having this issue for a while and never bothered to put in a bug report. Thanks for doing this moureyantoine.
Hello Stephan,
I'm following up on this issue as it has been about 10 months since the last update. Is there any news regarding the internal ticket?
I am still experiencing this clipboard break between RDP and SSH sessions, and it remains a significant hurdle in my daily workflow.
Thank you for your help!
Closed
