DLVS Console Instance Installer detecting SQL installation that is not there
Sup,
So today I was trying to install an instance on DLVS console, but noticed that it detected an SQL server installation I wasn't aware of. After checking "Add or remove" programs I saw there was a SQL installation which was seemingly unused, however even after uninstalling it, it still detects a SQL installation somehow despite there being none. Is anyone aware of this issue and how to fix it?
As you can see here, there is no SQL server installed anymore, so I really don't know where and how it is finding it, considering it isnt even running nor is there any active services running for it
Any help would be greatly appreciated.
All Comments (14)
Hello Max,
I'm Ben from the dev team. I suspect the SQL Server uninstallation may not have cleaned up everything properly. When we check whether SQL Server is installed, we essentially look at two things:
  1. Whether there's a registry key at HKLM\SOFTWARE\Microsoft\Microsoft SQL Server
  2. Whether there's a service whose name contains "MSSQL"
You can check for such a service using this PowerShell command:
sc query type= service | Select-String "SERVICE_NAME: MSSQL"
Let me know what you find!
Benoît Sansregret
