rdm powershell with sql connection, sql connection does not show
we have rdm with sql connection however i can only connect to the local connection. The sql database is not shown at all using the powershell commandlets.How can i connect to the correct SQL connection ?
We use powershell 5.1
PS D:\Beheer\Alex> Get-RDMInstance
ApplicationVersion OptionFilename
2022.3.1.8         C:\Users\TEMP.DF0.010\AppData\Roaming\Devolutions\RemoteDesktopManager\RemoteDesktopManager.cfg
PS D:\Beheer\Alex> Get-RDMDiagnostic
Serial LicenseType IsLicenseValid IsLicenseExpired
                            False             True
PS D:\Beheer\Alex> Get-RDMSession
Get-RDMSession : Connection not found.
All Comments (1)
It looks like you're using an older version of the module, which may be causing an error when reading the configuration. As a result, it’s likely defaulting to a local data source.
To avoid compatibility issues, we recommend using a module version that matches the major version of your RDM instance. Starting with version 2023.1, the module has been renamed Devolutions.PowerShell. Please note that this version requires PowerShell 7.5 or higher. Would you be able to test with a more recent version?
Alternatively, you could try using a portable version. Please see the documentation here: Use an Override Configuration (Portable)
Keep in mind that you'd need to recreate the data source. Also, if there’s a major version mismatch, you might still run into additional issues.
Maxime
Closed
