Web Client - Devolutions Gateway not inherited and leads to greyed out web client
Using 2024.3.6.0 - Devolutions Gateway is configured on a folder and the RDP entries in the folder are set to inherit gateway settings. RDM properly inherits and uses the gateway for the connection. However, on the web client, it shows "Inherit" but the web RDP button is greyed out ("Devolutions Gateway must be configured on the connection before the web client can be used"). Changing the gateway settings directly on the entry corrects the issue, but this requires batch editing to maintain across all entries, instead of inheritance.
I checked release notes for newer versions and didn't see an indication of this being resolved in a particular version.
All Comments (1)
From quickly testing on my end, with an RDP Session set to inherited and the Gateway configuration set on the parent folder, it seems to be working as expected; the "Open in web client" option is not greyed out and can be pressed.
This is on version 2025.1.4.0 of DVLS, did you need assistance with the upgrade?
Let me know,
Samuel Dery
