Scroll is extremely slow for ARD sessions
I am using RDM to remotely connect Mac from Arch Linux and everything works well but scrolling is extremely slow, it takes multiple turns to scroll a single line. I tried increasing scroll speed to max from mac but it did not have any effect. Most settings seem to be for physical mouse so does not have any effect. Any workaround to solve this is also appreciated.
Thanks
All Comments (5)
Hello jaydamani,
I was able to reproduce the issue. A ticket has been created, and we will let you know you once a fix is available.
Gabriel Dubois
Hello jaydamani,
Hello Gabriel
Thank you for the response, just wanted to check-in if there is any update?
Jay Damani
Hello Jay,
We do not have an update on this issue yet, but I bumped the ticket to a higher priority so we can look into it as soon as possible.
Gabriel Dubois
Hello Jay,
Hello Gabriel,
I just updated to the latest release and the issue is resolved now. This was an annoying issue so, I really appreciate the fix.
Thanks,
Jay
Hello Jay.
I'm glad you noticed the change. I forgot to update this thread saying that this issue had been fixed, I'm terribly sorry. In any case, please, do not hesitate to contact us again if you encounter any other issues!
Best regards.
Nicolas Parr
