Integrate Devolutions with SSO solutions other than Microsoft and Okta.
2 votes
We are currently using Devolutions hub solution and would like to explore the possibility of integrating it with our identity provider (IDP) solution. We have noticed that most password management solutions support such integration, and we would like to know if this functionality is available with Devolutions as well.
All Comments (4)
It's currently not possible; it's something that we might provide eventually. Which IdP do you have in mind?
Have a good day!
Maxime Morin
Pointsharp Idp.
I mean, if we can set it up like other applications with the following:
  • Entity ID
  • IDP Initiated Login
  • Assertion Consumer Service (ACS) Endpoint
  • Single Logout Service (SLO) Endpoint
  • SP Metadata
That would be great.
Currently, we support SSO integration with Microsoft and Okta using OIDC. Unfortunately, SAML providers like Pointsharp are not supported at this time, and there are no immediate plans to add SAML support. However, we are monitoring requests from other users and will consider it for future updates.
Maxime Morin
Thank you for your response.
It is surprising to hear that SAML is not currently supported, as nearly all major password management solutions and many other services widely support SAML for integration. In our environment, we have numerous services that seamlessly integrate with SAML, making it a standard for secure and flexible authentication.
We believe adding SAML support would greatly enhance the compatibility and appeal of your solution, especially for organizations like ours that rely heavily on SAML-based integrations.
