clipboard problem in Remote Desktop to windows machine
Resolved
I am experiencing an issue with the Remote Desktop Manager (RDM) software. When I connect to a Windows machine using RDM and attempt to copy a text file of approximately 3,000 lines, the remote desktop session disconnects and reconnects automatically. It seems that the clipboard cannot handle this amount of data efficiently.
Interestingly, when I connect to the same Windows machine from Linux using Remmina, I do not encounter this problem.
Could you please advise on how to resolve this issue in RDM? Is there a configuration setting or workaround that can improve clipboard handling for large text files?
Thank you for your assistance.
All Comments (2)
Hello Bahram,
Thank you for reaching out.
This is a known issue at the moment.
The development team is actively working on it, which should be addressed in future updates.
We apologize for the inconvenience caused.
Jacob Lafrenière
Hello Bahram,
The issue has been resolved in the latest release.
Please let us know if you encounter it again.
Simon Duguay Létourneau
