I have updated RDM to the latest version, and I'm running pwsh 7.4.5. My datasource is created through RDM on my SQL Server 2022 VM.
I can pretty much execute any powershell commands pertaining to RDM, but for some reason, whenever I attempt to use Set-RDMSession to create entries in the datasource, I receive the error, "Set-RDMSession: Your connection is not ready".
I have recreated the datasource, ensured the accounts I am using have full control over the datasource DB, but there's not change. Where can I go from here?
What do you get with Get-RDMCurrentDataSource?
What RDM and Devolutions.PowerShell module versions are you using?
Could you ensure that the RDM major and minor versions match the one of the PowerShell module?
If you use RDM 2024.3.x, then you must use the PowerShell module 2024.3.x.
Érica Poirier
IsConnected : True
IsOffline : False
Type : SQLServerGet-Module -Name "Devolutions.PowerShell"
ModuleType Version PreRelease Name ExportedCommands
Binary 2024.3.0 Devolutions.PowerShellRDM version: 2024.3.12.0
Powershell version: 7.4.5
Thank you for your feedback.
If the account you use in the SQL data source has enough permissions to create or update entries, it should work.
Could you please send your piece of code so I can test it? Ensure removing sensitive data it may contain.
Érica Poirier
The account used has full permissions to the datasource.
You can see below, that even quite simple commands fail with "Set-RDMSession: Your connection is not ready". I have also tried with templates, resulting in the same failure.
PS C:\> $session = New-RDMSession -Host "VII-DC01.viilab.net" -Name "VII-DC01" -Type RDPConfiguredPS C:\> Set-RDMSession -Session $session -Refresh -Verbose
VERBOSE: [Set-RDMSession] Start
VERBOSE: [Set-RDMSession] FinishPS C:\> New-RDMSession -Host "VII-DC01.viilab.net" -Name "VII-DC01" -Type RDPConfigured -SetSession -Verbose
VERBOSE: [New-RDMSession] Start
DocumentData :
HostResolved : VII-DC01.viilab.net
PsPlaylistLocal :
SubConnections : {}
UserSpecficSettings :
ConfluenceDocumentationUrl :
DocumentationExternalType : Default
DocumentationTitle :
DocumentationType : Markdown
DocumentationVariables : Default
ShowDocumentationTab : Inherited
AlternateShell :
AlwaysAskForResources : False
ApplicationIntegrationMode : Default
AuthentificationLevel : Default
AutoReconnection : True
CommandLine :
CommandLineWaitForApplicationToExit : False
CommandLineWorkingDirectory :
Console : False
DesktopComposition : False
DisableBitmapCache : False
DisableCursorSetting : False
DisableFullWindowDrag : False
DisableMenuAnims : False
DisableThemes : False
DisableWallpaper : False
DisplayConnectionBar : True
FontSmoothing : False
RDPFileName :
ScreenColor : C32Bits
ScreenSize : Default
ShellWorkingDirectory :
SoundHook : Default
Span : False
Url : VII-DC01.viilab.net
UsesClipboard : True
UsesDevices : False
UsesHardDrives : True
UsesPrinters : False
UsesSerialPorts : False
UsesSmartDevices : False
WebBrowserApplication : Default
WebBrowserUrl :
AllowPasswordVariable : False
AlternalteHostVPNBefore : False
AlternateHostAllowCustomHost : False
AlternateHostMode : Default
AlternateHosts :
AutomaticallyClose : False
AutomaticallyCloseInterval : 0
ClearTextPassword :
ClearTextPrivateKeyData :
Color :
ColorMode : Custom
ConnectionStringConnectionID :
ConnectionStringMode : Default
ConnectionSubType :
ConnectionType : RDPConfigured
ConnectUsingDashboardOnDoubleClick : Default
ContentType : Default
CreatedBy :
CreationDateTime :
CreationSource :
CredentialConnectionGroup :
CredentialConnectionID :
CredentialConnectionSavedPath :
CredentialDynamicDescription :
CredentialDynamicValue :
CredentialInheritedMode : Default
CredentialPrivateVaultSearchString :
CustomDnsServer :
CustomImageID :
CustomPort :
CustomStatus :
Data :
DataFileName :
Description :
DescriptionMode : Text
DescriptionRtf :
DescriptionUrl :
DisplayMonitor : Default
DisplayVirtualDesktop : Current
DocumentAllowExport : True
DocumentDataMode : Link
DocumentLinkConnectionID :
DocumentSize : 0
DomainHostOverride : False
DomainOverrideType : Default
Encrypt : False
ExcludeFromNotifications : False
ExludeFromOpenedSession : False
FavoritePath :
ForeColor :
ForeColorStyle : Status
GoOfflineOnConnect : False
Group :
GroupCredentialPrompt :
GroupMain :
GroupTab :
HasAttachedDocument : False
Host : VII-DC01.viilab.net
HostConnectionID :
HostConnectionSavedPath :
HostDomain :
HostFull : VII-DC01.viilab.net
HostNetworkInterfaceMac : en0
HostPort : 3389
HostSourceMode : SessionSpecific
HostUserName :
HostWithPort : VII-DC01.viilab.net
Image :
ImageMD5 :
ImageName :
IncludeInFavorite : False
IntelligentCacheAction : AddUpdate
IsFavorite : False
KeyboardHook : Default
OpenEmbedded : True
PamCredentialID :
PamCredentialName :
PamCredentialVaultID :
ParentID :
PasswordResolved : True
PersonalConnectionID :
PinEmbeddedMode : Default
PingConnectionMethod : Default
PingConnectionMode : Default
PingConnectionScanPort : 0
PrivateKeyConnectionID :
PrivateKeySearchString :
PromptCredentials : False
ReconnectMode : Default
RepositoryID : 00000000-0000-0000-0000-000000000000
RiskyEvents : Default
SealState : None
SensitiveResolved : True
SharedTemplate : False
ShowInTrayIcon : True
SortPriority : 0
Status :
StatusLockedBy :
StatusMessage :
SubMode : 0
SwitchDataSourceID :
SwitchDataSourceName :
SwitchRepositoryFolder :
SwitchRepositoryID :
SwitchRepositoryName :
SyncedDestination :
SynchronizedItemID :
TabGroupMode : Custom
TabTitle :
TemplateGroupData :
TemplateName :
TemplateSearchPath :
TemplateSearchPathMode : None
TemplateSourceID : a569b61a-57e9-457e-aeba-440d785a0a5e
Undocked : False
UndockMaximized : Default
UpdateDateTime :
UpdatedBy :
UserNameFormat : Default
UserVaultMigrationID : 00000000-0000-0000-0000-000000000000
Visibility : Default
WakeOnLANBroadcastIPAddress :
WakeOnLANPort : 0
ActiveDirectoryConsole : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSActiveDirectoryConsoleConnection
AddOn : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAddOnConnection
Agent : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAgentConnection
AI : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAIConnection
AppleRemoteManagement : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAppleRemoteManagementConnection
Autofill : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAutofillConnection
Aws : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAwsConnection
AzureBastion : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAzureBastionConnection
AzurePIM : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAzurePIMConnection
AzureStorage : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSAzureStorageConnection
BeyondTrustPasswordSafeConsole : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSBeyondTrustPasswordSafeConsoleConnection
BoxNet : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSBoxNetConnection
ChromeRemoteDesktop : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSChromeRemoteDesktopConnection
Citrix : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCitrixConnection
CloudBerryRemoteAssistant : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCloudBerryRemoteAssistantConnection
Cmd : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCmdConnection
ControlUp : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSControlUpConnection
Credentials : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCredentialsConnection
Customer : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCustomerConnection
CustomImage : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCustomImageConnection
CyberArkAccount : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCyberArkAccountConnection
CyberArkDashboard : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCyberArkDashboardConnection
CyberArkPSM : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSCyberArkPSMConnection
Dameware : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDamewareConnection
DataEntry : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDataEntryConnection
DataReport : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDataReportConnection
DCV : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDCVConnection
DelineaSecretServerProxy : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDelineaSecretServerProxyConnection
DellRemoteAccessController : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDellRemoteAccessControllerConnection
DeskRoll : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDeskRollConnection
DevolutionsGateway : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDevolutionsGatewayConnection
DevolutionsGatewayTunnel : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDevolutionsGatewayTunnelConnection
Document : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDocumentConnection
DropBox : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDropBoxConnection
DvlsPamDashboard : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSDVLSPamDashboardConnection
EntraIDConsole : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSEntraIDConsoleConnection
Events : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSConnectionEvents
FileExplorer : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSFileExplorerConnection
Ftp : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSFtpConnection
GoogleCloud : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSGoogleCloudConnection
GoogleDrive : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSGoogleDriveConnection
GotoAssist : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSGoToAssistConnection
GroupDetails : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSGroupConnection
HostDetails : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSHostConnection
HPIntegratedLightsOut : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSHPIntegratedLightsOutConnection
Hub : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSHubConnection
HyperV : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSHyperVConnection
IDrac : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSIDracConnection
ILO : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSILOConnection
Intel : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSIntelConnection
InventoryReport : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSInventoryReportConnection
ITerm : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSITermConnection
Jump : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSJumpConnection
JumpCommand : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSJumpCommand
JumpDesktop : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSJumpDesktopConnection
LogMeIn : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSLogMeInConnection
MetaInformation : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSConnectionMetaInformation
OTP : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSConnectionOTP
PAM : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSPamConnection
PAMProvider : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSPamProviderConnection
PlayList : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSPlayListConnection
PowerShell : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSPowerShellConnection
ProxyTunnel : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSProxyTunnelConnection
ProxyTunnelMac : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSProxyTunnelConnectionMac
Putty : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSPuttyConnection
Radmin : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRadminConnection
RDCommander : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRDCommanderConnection
RDGateway : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRDGatewayConnection
RDP : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRDPConnection
Recording : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRecordingConnection
ReportTool : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSReportToolConnection
Root : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRootConnection
RunAsConnection : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSRunAsConnection
S3 : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSS3Connection
Scp : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSScpConnection
Script : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSScriptConnection
ScriptDashboard : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSScriptDashboardConnection
Security : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSecurityConnection
Shortcut : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSShortcutConnection
SkyDrive : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSkyDriveConnection
SmartFolder : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSmartFolderConnection
SMB : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSMBConnection
SNMPReport : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSNMPReportConnection
Spiceworks : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSpiceworksConnection
SplashtopDashboard : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSplashtopDashboardConnection
Splunk : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSplunkConnection
Stats : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSStatsConnection
Sync : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSSyncConnection
TeamViewer : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTeamViewerConnection
TeamViewerConsole : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTeamViewerConsoleConnection
Template : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTemplateConnection
Terminal : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTerminalConnection
TerminalConsole : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTerminalServerConnection
TerminalMac : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTerminalConnectionMac
Ticketing : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSTicketingConnection
Tools : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSToolConnection
VirtualBox : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSVirtualBoxConnection
VMRC : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSVMRCConnection
VMWare : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSVMWareConnection
VNC : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSVNCConnection
VPN : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSVPNConnection
VPNMac : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSVPNConnectionMac
Web : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSWebConnection
WebDav : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSWebDavConnection
WindowsAdminCenter : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSWindowsAdminCenterConnection
WindowsTerminal : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSWindowsTerminalConnection
XenServer : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSXenServerConnection
XWindow : RemoteDesktopManager.PowerShellModule.PSOutputObject.PSXWindowConnection
UseVPN : False
VNCOptions :
VNCUrl :
VPNDomain :
VPNName :
VPNSafePassword :
VPNUserName :
VERBOSE: [New-RDMSession] FinishHello,
I cannot reproduce this issue on my SQL data source. This is a really strange problem.
What authentication method are you using with the SQL data source?
What do you get with these 2 cmdlets? Please hide sensitive data before posting it on the forum!
Get-RDMInstance
Get-RDMDiagnostic
Here is what I get using these cmdlets.
PS C:\> Get-RDMInstance
ApplicationVersion OptionFilename
2024.3.0.0 C:\Users\myuser\AppData\Roaming\Devolutions\RemoteDesktopManager\RemoteDesktopMan…PS C:\> Get-RDMDiagnostic
Serial LicenseType IsLicenseValid IsLicenseExpired
XXXXX-XXXXX-XXXXX-XXXXX-XXXXX None True FalseBest regards,
Érica Poirier
Good morning,
I'm using Windows authentication with the SQL data source, but I have also tried SQL authentication with the same symptoms.
2024.3.0.0 C:\Users\xxxxxxxx\AppData\Local\Devolutions\RemoteDesktopManager\RemoteDesktopManager.cfgPS C:\> Get-RDMDiagnostic
XXXXX-XXXXX-XXXXX-XXXXX-XXXXX Enterprise True FalseFYI - I have built a brand new environment to test and isolate the SQL server and workstation I've been attempting this on, and continue to get the same error.
We are trying to reproduce this issue to find a solution.
Could you send screenshots of your RDM SQL data source configuration and user account properties? Please make sure you hide sensitive information before posting the screenshots.
Érica Poirier
Both login modes produce successful connections below.
Test Host:
Test Database:
Thank you for your help! Please let me know if any further information could be helpful to you and your team. If I don't receive a response by the end of the day, then I hope you have a great weekend and look forward to resolving this with you next week.
