Devo Academy first impression
Resolved
Hi, so I got invited to the beta and only opened the page so here are the first few thoughts:
1) FAQ shouldn't go into continue learning (see image below)
2) Side scrolling is always bad, most computer mice don't have that option, in my opinion 2 columns with normal scrolling should be more convinient.
3) The community forum banner on top should have the little icon that tells you it will open a new tab on another site. Although it may be more convinient to embbed it in the academy.
4) In the view all section there should be filters to better find what you need even when you don't know what to search for, at the moment it's just an endless list with 3 pages (which will go up). Add filetring by difficulty, subject maybe even add a suggested "flow" for courses that go together in a specific order.
That's all for now, once I'll have time I'll view some of the courses and add more thoughts.
Ben
All Comments (8)
Continuing:
5) Videos should have better resolution, it's no sharp and because of it a bit unpleasnt to watch.
6) In each course add in the side bar the suggested related courses. For example "Managing Entry Permissions" should link to course about devolutions permissions sets.
7) Add the ability to create a list of courses the user wants to do so they can choose them ahead and can find them without having to look through everything again.
First of all, many thanks for inviting me to be a beta tester for the new Devolutions Academy.
I didn't have much time to check out the Academy thoroughly, but here are a couple of things I noticed immediately when opening the site.
  • Good to see the Academy is in the same style as all the rest of Devolutions products
  • Do not start with "Home" (which is the landing page), as is shows courses in random order and level. I would suggest making the "Courses" page the landing page.
As there the courses are in chronological order, based on level (beginner, intermediate, advanced). Maybe even remove the "Home" page, as it serves not a real purpose.
Or make a page called "Progress" where everyone can see which courses they started and finished.
  • When I paused a video/course and I want to resume it, there's the "Resume" button but the video starts playing from the beginning. It would be better to have the video start from where it got paused.
  • When clicking on the "Community Forum" I had to re-login. I was not able to respond to this forum (and hence, write this first impression). The login went automatically, but only when I clicked on the "Login" button. It would be better when coming from the Academy and want to go to the forum, it got automatically get signed in with same user account (not the extra press on login button).
As I have more time, I will share more opinions.
But the idea about this Academy is great !
Like the idea !
