Enforce master password and auto lock
Please, is it possible to add an option to enforce master password for all users?
For the moment in administration/system settings/RDM and companion tools, there's an option to “Enforce biometric lock”, but nothing to « Enforce master password » for all users. Furthermore, it seems that there's no admin option to auto-lock after x minutes of inactivity or when app is in background for all users.
Thanks for your time. Have a nice day,
Marc-Andre
All Comments (8)
Just to be sure, are you using RDM or Workspace or both?
Thank you, have a good day!
Maxime Morin
Workspace only. Thanks.
Hi, currently there is no way to 'force' these settings for users. I will add these to our roadmap and keep you updated on the completion.
Thank you,
Sébastien Aubin
Product manager - Password Management
The "Enforce biometric lock" setting also works for the Master Password. We would just need to change the label in the Hub Business administration to make it clearer. Once activated, it will perform the intended function.
Regarding inactivity, we have a setting for that in the Hub administration. The Workspace application will follow this setting, but it will only lock the workspace, not the entire application.
Would this meet your needs, or would you prefer a setting that locks the entire application?
If you need further information on activating this inactivity setting, just let me know, and I will guide you through it.
Thank you,
Sébastien Aubin
Hello Sébastien,
Just to be sure, if I enable "Enforce biometric lock" in administration/system settings/RDM and companion tools, it would do the same thing as if I configure in workspace in the gear icon/security and privacy, the "Use master password"? About the inactivity, there's 2 parameters "Auto lock" after x minutes and "Background lock" in workspace app that will lock the app ask for a master key. The option that you talk about in Hub administration will do what exactly? Where do I configure this? Thanks for info.
