Allow read only users on Administration
Hi, for audit purposes we need to grant certian people access to specific section in the administration area and currently there is no way to do it as read only, even if the user is read-only role.
Can the permissions for administration be a bit more fluid?
Thanks,
Ben
All Comments (5)
Hello Ben,
Thank you for your request. We have a few permissions available in "Administration > System permissions" that could help you if what they need is reports mainly.
We know that lot of administration sections require administrator to have access to it. Long term, we would like to split administrator rights to be able to assign specific rights to users. But we don't have ETA for that. Could you elaborate more on what are your needs during audit ? We could see if something could be improved.
François Dubois
I know about the reports buy they are not helpful for this matter.
The audit requires screenshots of the users console (I know it's dumb as hell) so for example I would like to grant read only access to there.
As we are diving deeper with the PAM and implementing it for everyone I guess some other requirements will pop up.
Thanks,
Ben
Hello Ben,
Thank you for your answer. I understand your need for a read only user and we have already received similar requests. As I said, mid/long term, we would like to split the administrator rights in many roles to be able to give only few rights to users, but it could take long time. For now, at least for users, there is a report that is same as the users console
It could help for users, and don't hesitate to let us know what else could help. We keep your request in mind and let you know once we have an update on that.
François Dubois
Hi, I did check the reports and it seems to be perfect for our needs so for now it should be enough until something else pops up!
Thanks,
Ben
I'm glad to hear that it can help for now even if it is not the perfect solution. Don't hesitate if we can help with something else.
François Dubois
