Being able to send to Launcher from web interface
I've noticed there is an option to launch sessions from within the web interface and send it to RDM. However the option right next to it, to send to Launcher is always grayed out. Since most of our users feel the web interface is more fluide, they would like to bypass Workspace and only use the web interface and the launcher.
Would it be possible to have the option to send a session request to open from the Launcher.
Thank you
All Comments (2)
Hi @ericdancause,
To enable the Launcher button in the web interface, you need to ensure that you have a valid Launcher license in Hub Business and that you assign users to the license.
Documentation for Launcher licenses assignation: https://docs.devolutions.net/hub/launcher/installation/launcher-license-registration/
Since you've mentioned that you prefer to stay within the Hub Business interface, we have implemented web-based sessions over the past year. Currently, RDP, VNC, Telnet, SSH, PowerShell, and ARD are supported. You would require having a license to Devolutions Gateway and installed. Here's a demo for you to look into: https://youtu.be/cOHt3oBE8DA?si=PAxPORI66HZtjq3U&t=357.
Documentation for Devolutions Gateway with Hub Business: https://docs.devolutions.net/dgw/hub/hub-business-configuration/
If you have any further questions or need additional assistance, please let us know.
Maxime Forest
Thanks Max,
This really helps us out :)
