Gateway farm in Hub
In DVLS it is possible to create a gateway farm to accomodate HA/failover between gateways. This option does not seem to be available in Hub currently.
Thanks
Joe
All Comments (9)
Hi Joe,
Thank you for the suggestion. Supporting Gateway farms is already in our backlog.
Have a good day!
Maxime Morin
Thanks Maxime, is there an ETA?
Hi Joe,
Not really, I can say that's it's not planned for 2024.3 which is expected to be released around October 2024. It could be targeted for 2025.1, if it makes the cut.
Have a good day!
Maxime Morin
Hi Maxime, any update on whether gateway farms with be available in Hub for 2025.1?
It's on the planned feature list and I hope this will be completed for the January release.
Thanks David, that sounds great.
This is something we actually need, how's the progress on this? In the meantime are there viable alternatives like a reverse proxy with loadbalancer in front of two gateway's?
Gateway farms are currently being worked on; they are expected with 2025.1, which is targeted for January/February.
As for workarounds, it's probably technically possible, but it's not something that we have supported or tried before.
Have a good day!
Maxime Morin
Have a good day!
Can't wait! Thanks.
