Add a way to view User Vault connection logs
Hello, we are enabling the User Vault in our DVLS environment, and i found that there is no way to see to which systems the users are connecting to from there in the console.
So my request is to have a way to, lets say "Administrators" in DVLS, to view in the Activity Logs the user vault logs of connections only at least.
If we can not do that we are losing the audit part with our customers to where and whom was connecting to their systems.
Also if you can select which kind of entries they can create on the user vault, lets say only credentials, that will be solved in our case.
Both options are good to have the audit on what they can do from there.
Please let me know if I was clear.
Best regards
Nicolas
All Comments (2)
Hello Nicolas,
An administrator should already have access to the report Activity Logs. In that report, you should see all actions made by your users. Here is an example
If the vault column is empty, it means that it is a user vault. You can also see which user it is by the column User. It could be clearer that it is a user vault (I will create a ticket to write "User Vault" instead of nothing), but the information should be available.
Let me know if that help.
François Dubois
