filter on entry type
hi!
it would be great to filter also for the entry type.
for example: when I filter for "hostname customer" I get results with entry types of "web session", "rdp connection", "credential" - to filter for a specific type I would love to append "rdp", "web", "cred" to get only that one entry I am looking for and - in case of web and rdp - hit enter to open that one connection.
KR
G.
Hello Guenther,
This should already be possible with how our filter works. Could you try typing "hostname customer && Website" for example if you're looking for website entries?
Here's an example on my end that works. I have two entries called ABC, one is a Website, one is a credential:
In the filter, I make sure to configure to include the type of the entry in the filter:
Then, if I enter the string "ABC && Website", it only shows the Website-type entry, while filtering on the name "ABC":
Let me know if this doesn't work for you, maybe I'm missing something in your scenario.
thanks Hubert,
this works as expected!
KR
G.
Glad this works for you, let us know if you have any other question or request.
