I'm trying to get all SshShell sessions using the DS powershell commands and found that Get-DSEntry gives different output depending on how i use the command.
Can you please explain why the command doesn't give the same output?
If i first have to run "Get-DSEntry -VaultId $Vault.Id -All" to get all entries and then again run "Get-DSEntry -EntryId <ID>" or "Get-DSEntry -VaultId $Vault.Id -FilterBy Name -FilterValue <NAME>" for each object that has connectionType 77 (or SshShell, which only the command with filtervalue shows) then i have to make a lot of unnecessary call to the API to get the information that in my opinion should come with getting all entries (except the secret data of cause).
Module version: 2023.2.0.6
(Get-DSEntry -VaultId $Vault.Id -All).Data | Where-Object {$_.Id -ieq 'c57e1505-e79e-4974-9b1f-f3eab6947333'}
connectionType : 77
displayMode : 1
displayMonitor : 4
group : Test\TestFolder
permissions : @{canView=True}
repositoryId : 7e14f5e8-8747-482c-b2aa-91104866aafa
supportSessionRecording : True(Get-DSEntry -VaultId $Vault.Id -FilterBy Name -FilterValue 'TestSSH').Data
CachedSecurityGroups :
SplittedGroupMain : {Test, Test\TestFolder}
AttachmentCount : 0
AttachmentPrivateCount : 0
ConnectionType : SSHShell
ConnexionTypeIcon :
ConnexionTypeString :
Data : <?xml version="1.0"?>.....
DataAtRestDecrypted : False
DeserializedConnection :
Group : Test\TestFolder
GroupMain : Test\TestFolder
Groups : {Test\TestFolder}
HandbookCount : 0
IntelligentCacheAction : AddUpdate
InventoryReportCount : 0
IsPrivate : False
MetaData : Devolutions.RemoteDesktopManager.Business.Entities.ConnectionMetaDataEntity
MetaDataString : <?xml version="1.0" encoding="utf-8"?>.....
ParentID :
RepositoryID : 7e14f5e8-8747-482c-b2aa-91104866aafa
SecurityGroup : 00000000-0000-0000-0000-000000000000
TodoOpenCount : 0
Version : (Get-DSEntry -EntryId c57e1505-e79e-4974-9b1f-f3eab6947333).Data
resolvedCheckOutMode : 5
resolvedCheckOutCommentMode : 1
resolvedAllowOffline : 1
resolvedSynchronizeDocumentToOfflineMode : 2
resolvedTemporaryAccessMode : 3
resolvedCredentialConnectionId : c57e1505-e79e-4974-9b1f-f3eab6947333
connectionType : 77
createdBy : account
createdDate : 2023-09-13 20:03:38
data : ....
displayMode : 1
displayMonitor : 4
modifiedBy : account
modifiedDate : 2023-09-13 20:05:56
resolvedTimeBasedUsageSettings : @{timeBasedUsageDays=2}
sessionRecordingSettings : @{fileNameMode=3; mode=4; sessionRecordingTarget=1; cid=c57e1505-e79e-4974-9b1f-f3eab6947333}
resolvedEventsLogsOptions : @{openLogsOptions=; closeLogsOptions=; credentialsViewedLogsOptions=}
accessRequestResolvedAuthorizerSetting : 2Hello,
I verified with the PowerShell developer, and here are his comments:
The EntryID parameter is a lighter version of the entries. It was chosen to restrict the amount of data transferred.
For the type with Filter, the result is similar to using the AsRDMConnection switch. Get-DSEntry -EntryID $id -AsRDMConnection returns an object with the ConnectionInfo property, which is exactly what the command with Filter returns.
For the result with -All, the possibility of searching in all vaults implies too many entries, so a minimal object is returned. It is less necessary now that Search-DSEntry cmdlet exists.
Let us know if you need additional information!
Richard Boisvert
Hi
Thanks for the answers and i understand why you would restrict the amount of data transferred. But if you have to find all the entries you wish to get info about and then run a command against each entry again to the the extended dataset, wouldn't that be more data transferred than if you returned it all in the first place?
I didn't know about Search-DSEntry but i can use it and then for each entry run Get-DSEntry -EntryId to the the extended data where i can find the hostname i need.
What would be the right way to change the hostname of the entry?
Hello thoj,
To update an entry, you would need to use the cmdlet Update-DSEntryBase . To get the ID of the entry, it works well with the Search-DSEntry, as mentioned above.
Here is an example to update the hostname of an RDP session. This will search all vaults for the exact name you search for:
$id = (Search-DSEntry -By Name -Match ExactExpression -Value 'name of entry').data.id
$Entry = (Get-DSEntry -EntryId $id).Body.data
$Entry.data.host = "new hostname"
$Entry = (ConvertTo-Json $Entry -Depth 10)
$update = Update-DSEntryBase -jsonBody $EntryBest regards,
Richard Boisvert
