Implemented
Open session with double click
It would be nice to enable launch sessions from Workspace (eventually Hub web GUI) with double-click on an entry and have it open in the Launcher without having to press the "Open in Launcher" button in the top right corner
All Comments (8)
Hi, thanks for the request. We will add this on our TODO and let you know when it's deployed.
Thank you,
Sébastien Aubin
Product manager - Password Management
Hi, this feature is now present in the new Workspace version (2023.2.3).
Thank you,
Sébastien Aubin
Hi, thank you for implementing, it's much comfotable now.
Is it possible to set the default behaviour somehow - directly open the session, not choose the app? I don't have RDM installed, so it would be nice directly open Launcher session (and vica versa - only RDM installed -> opend RDM session).
Thank you
Hi, sure, we will add this option in the Settings section in the next release.
Thank you,
Sébastien Aubin
Hi, the setting is now avalaible in the latest version of Workspace.
Sébastien Aubin
Thank you for implementation, it works great.
Hi would it be possible to have the information as to where this default setting can be set ?
Hi, absolutely! On the desktop app you can:
  • Open the side menu
  • All the way to the bottom, click on "Settings"
  • In the Settings prompt, you can select "Entries" on the left
  • In the "Entries" section, there is a section named "Open connection" where you can set it up
This feature is only available on the latest version on Workspace Desktop (2023.2.4)
Sébastien Aubin
