Quick Start Guide?
is there an operations manual or a quick start guide? I have it installed and I think properly working. Now I just want to use it. The manual seems focused just on install methods.
I simply want to:
  1. Import a TSV or CSV as a method of importing passwords.
  2. Manually add password
  3. Then figure out how to share.
All Comments (1)
Are you using Remote Desktop Manager or intend to use the web interface to perform the import?
for RDM: https://docs.devolutions.net/rdm/windows/commands/file/import/generic-csv-wizard/strategies-file-format/
For the web interface I could whip something up tomorrow
For the permissions
https://docs.devolutions.net/server/web-interface/user-groups-based-security/#create-the-user-groups
Maurice
