Permission inheritance on entire vault.
Resolved
We are trying to streamline permissions on our infrastructure by defining the groups permission on the root folders and letting all connections within a vault inherit those.
I was wondering if their was a simple way to identify if a session has fully inherited permissions or if some are custom?
The best 'brute force' approach I found was the following, but I am unsure if this might break the access to sessions:
# Recovering the sessions from within the vault with
# specific permissions
$Sessions = Get-RDMSession | ?{$_.Security.Permissions.Count -gt 0}
# Removing existing peremissions for the found sessions
foreach($Session in $Sessions){
  $Session.Security.Permissions.Clear()
  Set-RDMSession $Session
Would this be a viable approach or should I also modify other properties?
Alexis De Jaeger
You can test if the RoleOverride property is set to Custom to know if there is any specific permissions set on this entry.
$Sessions = Get-RDMSession | ?{$_.Security.RoleOverride -eq 'Custom'}
Then, to remove all permissions, just set the RoleOverride property to Default.
$Session.Security.RoleOverride = 'Default'
Let us know if that helps.
Érica Poirier
Hi Erica,
It does exactly what I wanted to do.
Thank you very much for your help.
Alexis De Jaeger
Hi Alexis,
Thank you for your feedback and glad that the provided solution was helpful!
Érica Poirier
Closed
