Problems with DVLS/RDM Notifications
Implemented
There seems to be strange behaviors regarding this.
I have set up to send notifications when entry type folders are created or deleted but I only recieve email notification for creted folder entry IF i don´t have any more filter added than "Action is Created".
If i add a filter that the entry type should be "Folder" i don´t get any email when a folder is created
Also , i don´t get any email when an entry is deleted with a notification setup for this.
Is there any log i can check if something acctually happens when it is supposed to ? Like i want to se if the system has tried to send a notification
Running DVLS 2023.1.7.0 and RDM 2023.1.23.0
All Comments (17)
What folder type have you created or deleted?
As many folder types can be created (Company, Customer, Server, etc), we need to specify them in the Subscription dialog as shown in the following screen capture. You should have 12 folder types row in the subscription Filters section related to folders.
With this Subscription, I receive a notification for every folder type I create or delete.
Let us know if that helps.
Érica Poirier
