We have the following problems with Devolutions Web Login connected, to DVLS with a Vault with Websites Entries.
If an URL of a site changed from https://www.xy.com to https://www2.xy.com it won't recognizes the websites entries in the vault anymore, and displays no entries. I know there is the function to add similar entries, but normalle I would just search in the window trough all entries with the name of the Website entry in the vault and use it like that. (thats also how it works in the autofill of the app) But here it seems I can't search any other entries, when they don't have the exact same URL. Is this a bug or if is by design, can this please be changed. As it makes no sense to have a search box here, which could only search in already found entries.
.2. When I open an entry via the App integration in the browser taskbar and say View, and after that more -> edit:
2a. First when I change just the URL and nothing else, and hit save. The password will be removed after saving. It's just empy.
2b. If I want to display the password in the EDIT dialog and hit the eye, it will open a blank page without the password:
Thanks for checking.
Patrick
