Security settings on entry in PAM vault
Resolved
Is it possible to set permissions on a per entry level inside a PAM vault? I want to allow only one spesific users to see a spesific PAMuser.
All Comments (4)
You can assign the permissions to a PAM account directly, for example with the Inherited + Custom permission. To be able to use an account, you need to grant them at least Operator permission. They will also need to have access to the PAM vault. If the account is in a folder, the user will also need to have the rights to the folder.
Richard Boisvert
Thanks that solved it.
Hello @Richard Boisvert, in your message it looks like we can set permission on folder in the pam vault but i cannot find a way to do so. I can set permission on accounts but not on folder. Am i missing something?
Hello Pierre,
The security can only be assigned at the PAMvault or the entry level. In the above screenshot, it was for a PAM vault.
If you would like to be able to add permission at the folder level, I would suggest adding a topic on the feature request section of the forum: https://forum.devolutions.net/forums/34/devolutions-server--feature-request
Richard Boisvert
