Connecting to MacBook from iPad Air 5 using Magic Keyboard - shift and other modifier keys not recognized
Resolved
Connecting to my MacBook Pro running current version of Ventura over ARD from RDM on my iPad Air (5th ed). I successfully get connected as far as seeing the MacBook’s lock screen, but I’m unable to login using my Magic Keyboard. I have to disconnect the iPad, and use the soft keyboard to enter my password.
Through testing, I’ve determined that the problem is caused because none of the modifier keys on the keyboard seem to work, i.e., if I press Shift+t , it comes out as lowercase t. Shift+/ is still /. and so on. The on-screen ones provided in the RDM window don’t work either with the hardware keyboard. I literally cannot get an uppercase letter unless I switch to the soft keyboard.
The soft keyboard generally works as expected..
All Comments (6)
Thank you for reporting the issue, we will look into it.
Maxime Brousseau
We have released a new version 2023.1.6. It includes a potential fix for your issue.
Let us know if it works.
Maxime Brousseau
It worked in 2023.1.6, but it’s broken again in 2023.1.7.
Best,
Jim
We are able to reproduce the issue. We will release a fix as soon as possible.
Sorry for the inconveniences.
Maxime Brousseau
If you update to the version 2023.1.8, it should work as it did in version 2023.1.6.
Again, sorry for the inconveniences.
Maxime Brousseau
Thank you! Installed .8 and it’s working correctly again.
Jim
