devolutions web login not showing host entry for web login
Resolved
Hi
Lately, I've changed a few entries from the type "Website" to "Host" with two separate Templates called "SSH Login (SSH Shell Entry)" and "Webinterface Login (Website Session Entry)".
Since the change, our browser extension does not recognize the logins anymore.
My guess is that, because there's no "real" entry with the correct URL, the extension (for good a good reason) cant find an entry to display for auto-fill.
Is there any way to be able to still pass the "Website Session Template Entry" to the browser extension so we can auto-fill the login?
Current workaround is a duplicate entry. One as a "Host" type and another one as a "Website" type. Second one will just be used for the browser extension.
Maybe there already is a solution to this and I am just missing out on it :)
Alex
Unfortunately, host entries cannot be used with DWL, neither can it use a template. You could always have a sub-entry to the host entry that uses the $PARENT_HOST$ variable in the URL of the website:
Richard Boisvert
Thanks, that is a usable solution for me.
Just one last question: I think our "it integrator partner" has deactivated the options for sub-entries during initial setup. how do I re-enable them?
Great! Let us know if you have any issues with it.
To enable the feature, in RDM, go to Administration > System Settings and set the "Allow sub entries" to yes.
Richard Boisvert
