Implemented
ssh does not work
environment:archlinux, RDM 2022.3.1.3
After the SSH session is created, double-clicking does not respond and no logs are generated, while RDP and web session both works fine.
Does anyone know what the reason is?
All Comments (6)
Hi archblux,
Do you mean that the double click do not highlight the text or RDM is crashing/freezing?
Is your session embedded or undocked?
Gabriel Dubois
Hi archblux,
Regard
nothing happened..
Whether embedded or undocked, whether double click or context menu, the SSH terminal window never opens
Hi archblux,
I can't reproduce the issue on my side.
We just release a new version (2022.3.2.1) is your issue still occur in this version?
Gabriel Dubois
Still not working
On the same host, SFTP works, but SSH does not
Hi archblux,
Thank you for the video, this is very helpful. I opened a ticket and we will investiguate this issue as soon as we can.
Gabriel Dubois
Hi archblux,
I've been investigating this issue and I can't seem to reproduce it with any of the SFTP connections I can test with. Is there any way you could show us your logs after trying to launch the connection via SSH Terminal? You should be able to see logs by running RDM via your CLI.
Thank you
Nicolas Parr
