DVLS Module: How to correctly set data.Connection.Security on Entries?
Resolved Implemented
Hi All
Whats the correct way to set the Permissions for specified Entries?
Thanks,
Andreas
All Comments (9)
Hello Andreas,
The permissions can be updated or set using the ConncetionPermission object you can apply using the Set-DSEntityPermissions cmdlet.
Here is a sample script that grants the View and View Password permission for group1 and group2 on a folder.
$vaultID = 'a9bd63e8-ebc4-488e-90bd-5d73f613821a'
$folderid = ((Get-DSFolders -VaultId $vaultID -IncludeSubFolders).body.data | Where-Object { $_.name -eq "FolderName" }).id
$folderPermissions = @(
    [ConnectionPermission]@{
        IsEmpty  = $false
        Override = [SecurityRoleOverride]::Custom
        Right    = [SecurityRoleRight]::View
        Roles    = @("group1","group2")
        IsEmpty  = $false
        Right    = [SecurityRoleRight]::ViewPassword
Set-DSEntityPermissions -EntityId $folderid -Permissions $folderPermissions
Let us know if you have further questions about it.
Érica Poirier
Hi Erica
I tought that only works for Folders, but you're completely right, it works also for entries on my side 😉
Thanks a lot!
Best Regards,
Andreas
Hi Andreas,
You're more than welcome!
That's right, it woks on single entries too.
Érica Poirier
Hi Erica, I've tried to use the Set-DSEntityPermissions command to change permissions on a folder but I get a not recognized cmdlet error.
Is there a new way to accomplish that ?
I use version 2023.1.0.6 of Devolutions.Powershell.
Hello Boris,
Thank you for pointing out that this cmdlet is missing from the module.
The Set-DSEntityPermissions is not actually in the Devolutions.PowerShell module. We will soon release a new version of the module that will include the missing cmdlets.
We will let you know once it will be available.
Thank you for your patience.
Érica Poirier
The latest release (2023.1.0.7) with Set-DSEntityPermissions is now available.
Jonathan Lafontaine
Hey Jonathan
Im a little confused, because your Post is 13 Days old now and PSG still only has v2022.3.13.0.
Also on Git:
Where can i find 2023.1.0.7?
Best Regards,
Andreas
Hello Andreas,
For your information, all PowerShell modules has been merged into one, the Devolutions.PowerShell module you can find on PSGallery.
https://www.powershellgallery.com/packages/Devolutions.PowerShell/
Here is the online documentation about it.
https://docs.devolutions.net/kb/remote-desktop-manager/knowledge-base/rdm-powershell-core-module/
https://docs.devolutions.net/kb/devolutions-server/how-to-articles/powershell-connectivity/
You'll have to uninstall all existing modules to be able to install it.
Let us know if you have further questions about this.
Érica Poirier
Thank you very much Erica, i totally missed that Part.
Best Regards,
Andreas
