I wanted to test the Devolution Workspace, but it does not work for any user.
It simply hangs during the loading process.
Do I have to activate something on the Devolution Server?
Thanks for any support.
br
Markus
There is nothing to enable in the DVLS settings to access it from Workspace.
What DVLS version are you using?
Could you please share a screen capture of the problem you get?
Érica Poirier
thanks for reply.
We use the DVLS Version 2022.3.8.0.
The ring for loading, remains in place:
br
Markus
Thank you for your feedback.
Could you please try to update your Workspace application to the latest 2022.4.1.4 version?
If this is still not working, please try to disconnect and reconnect on DVLS. You can click on the DVLS icon in Workspace and click on the Log Off button.
Let us know if that helps.
Érica Poirier
Hi Erica,
with the new version the data are loaded from DVLS.
Thanks for your Help.
Br
Markus
Hello Markus,
That's a good news that installing the new version has solved the problem.
Érica Poirier
