I've upgraded Devolutions Server to version 2022.2.5.0 yesterday and since then, some of my users are unable to login within the Edge add-in with Microsoft 365 Azure login. The login process initiated by the add-in goes well to Azure AD but then came-back with and error "Could not login to Devolutions Server. Please contact your administration".
The login process works correctly with Administrator rights
Azure AD Logins for this user are successfully allowed for the same entry.
They are able to login successfully with web interface and use the vault.
In the Devolutions Server logs, there's an error saying "NullReferenceException" everytime the Edge login is tried for this user (see attached screenshot)
In Administration Logs, it says "Access denied - Not allowed to view entry" but the same user was working correctly before the upgrade.
We had a similar issue with another client, we are verifying the issue with the engineering team.
Once we have more details, I will update the thread.
Richard Boisvert
