Implemented
More info on Web
Hi
Please add UPN and Custom Fields to the Web - And make a "Copy"-icon for each of them in the overview.
Regards Lars
Remote Desktop Manager connected with Devolutions Server running newest versions.
------------------------Signature------------------------
Sorry if any of above sounds harsh or provoking, it is NOT meant as such, but I have Asperger's and don't always know.
My intentions is always to be friendly.
All Comments (13)
Could you give us more context where you would like to see UPN field and custom fields on the Web ?
François Dubois
Hi
For enties for instance like here:
forum image
Just to be sure that I understand correctly, you would like to see the username, the password, but also the username with UPN format ? In your example, you don't have a domain defined so it would not exist, but in this example, you would like to see the Administrator@ad.it-help.ninja ?
forum image
And for the Custom Fields, are you talking about those fields available only in RDM ?
forum image
François Dubois
Sorry for the late reply
Yes, correct, like you do on Password Hub Business
forum image
Regards Lars
Hi
Any update on this?
Regards Lars
I don't have an ETA for now, but it is still on our improvement list.
François Dubois
I have implemented DVLS now for our organization, but has ran into the issue, that my users who only have web read access, can't see the "host" entry on a folder.
Would there be any chance that the below 2 informations of a folder can be visible on web on the next release of DVLS ? - Else I will have to have the information two places :(
forum image
You can use the variables to add the information in the Description property like this :
forum image
To update the existing entries, you can use the Batch Edit feature.
https://help.remotedesktopmanager.com/commands_batchedit.html
And finally, when creating new entries, you can create them using a Template.
https://help.remotedesktopmanager.com/commands_creatingtemplates.html
Let me know if that helps.
Érica Poirier
Ahh, of cause, I keep forgetting about variables. Thanks!
A update for future reference.
the $IP$ variable is for the Asset IP
In my case I have the IP in the IP field found when "Server is selected as folder type. To get this ip use $COMPUTER_IP$
Hi
Any update on this?
Regards Lars
As per the available information, this request hasn't been implemented yet internally. As the engineering team already ironing the next version 2022.2, this request won't be part of this new version.
Once it will be available, we will post it here.
Thank you for your patience.
Érica Poirier
We just released a beta version containing what we discused in that thread, an UPN and custom field added in the overview of an entry. For more information on the version : https://forum.devolutions.net/topics/37615/version-2022230-june-20th-2022
Thank you for your patience,
François Dubois
Ends in 2 days
