Devolutions Launcher error when using 2FA
Newer install here, still getting comfy. When using 2FA (google in this case) logging into the launcher generates an error:
System.AggregateException: One or more errors occurred. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at Devolutions.Launcher.Managers.WebSourceManager.<TryLoginAsync>d__15.MoveNext()
   --- End of inner exception stack trace ---
   at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
   at Devolutions.Launcher.Sources.Dps.DvlsWebClient.HandleWebException(WebException ex, Boolean& retry)
   at Devolutions.Launcher.Sources.Common.RestClient.GetResponse(WebRequest request, Boolean allowRetry)
   at Devolutions.Launcher.Sources.Common.RestClient.<GetResponseAsync>d__52`1.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Devolutions.Launcher.Sources.Dps.DvlsWebSource.<LoginCoreAsync>d__12.MoveNext()
   at Devolutions.Launcher.Sources.WebSource.<>c__DisplayClass13_0.<<LoginAsync>b__0>d.MoveNext()
---> (Inner Exception #0) System.NullReferenceException: Object reference not set to an instance of an object.
   at Devolutions.Launcher.Managers.WebSourceManager.<TryLoginAsync>d__15.MoveNext()<---
Launcher and DPS are both current versions. Turning 2FA for the user to none = no errors.
All Comments (5)
What version of Devolutions Server are you running?
What version of Devolutions Launcher is installed on your workstation?
Server is 2020.3.17.0
Launcher is 2021.1.2.0
Thank you for your feedback.
I have been able to reproduce the issue internally and a ticket has been submitted to our engineering department.
Once an update will be available, we will update this thread.
Thank you for your patience.
Érica Poirier
Hi, any updates?
The ticket is still opened on the engineering department side.
I asked them some development. When they will came back to me, I will then came back to you.
Unfortunately, I cannot provide any ETA for now.
Closed
