Wayk Agent Popup on remote machine
can you please implement an ability to disable the Wayk Agent popup on the remote machine, at least when connecting to headless machines via physical connection (and/or SRD). It's really useless that I have to click it away each time I connect - it's only bugging me, and nobody else.
All Comments (2)
Hello
You can view some previous discussion on the topic here. I suspect there may be one or more other threads discussing the same thing, but the links escape me at this moment.
I understand why it can be annoying but it's something we're quite hesitant to change. We have some internal discussion about this and I'll make sure to add your "+1" voice to that.
Thanks and kind regards,
Richard Markievicz
Thanks, appreciate it.
