DPS Web / Reports - Display more entries per page
Hi
Various reports can be displayed in DPS Web.
Sadly only 10 entries per page are displayed. After that you have to switch to the next page.
I have not found an option in the settings where I could change/increase this
I would like to have an option here in which i can choose how many entries should be displayed on one page
This could be done with a dropdown selection with the options e.g. 10, 25, 50, 100, 250, 500 or something like that.
What do you think?
Best Regards
Simon
All Comments (2)
Hi Simon,
that's a good idea, we should add an option per report for the number of results per page.
Currently, you can set the number of results per page in your settings.
You can access it by clicking on your avatar on the top right of the screen and click on settings. You should see a settings dialog with the "Grid page size" option.
I hope it helps,
David
David Savard
Hi David
Thanks for the quick feedback.
I look forward to the new option.
For the moment I have adjusted the settings according to your tip to 50.
Thanks for that. This helps.
Best regards
Simon
