Installing on non-Ubuntu system
I wanted to install this on a system running Solus 4.1. Is it as simple as just extracting the .deb file, or is there another way to install it?
All Comments (1)
We are only distributing deb files to install RDM.
You can, however, extract the deb file and run RDM from the extracted folder.
Just make sure to run the commands in the postinst script. It generates certificates required by the mono framwork.
You will need to have the ca-certificates package installed for your distro and modify the script commands if they don't install in the folder as Ubuntu's.
Jonathan Lafontaine
