Wayk session window spawns top left regardless of taskbar position
my1
Disabled
thereby making the menu bar hard to access if one is using a top taskbar (like me)
Using Windows 8.1
All Comments (5)
Hello
I can't reproduce that on Windows 8.1 or Windows 10 1909, using Wayk Now 2020.1.7 and a "top" taskbar.
Can you post a screenshot demonstrating the issue, just to be sure I'm not misinterpreting the bug report?
Thanks and kind regards
Richard Markievicz
my1
Disabled
check the top edge here:
and yes it is 2020.1.7
Hello again
Ah ok - thanks for the screenshot, that helped isolate the issue. Previously my VM screen was quite a bit smaller than the remote one, which forces Wayk to set the auto zoom and the window is resized to accommodate. If the local display is larger than the remote one, then reproducing your issue is quite easy.
I've entered a work item to fix that and I'll post back here once I have an update on that. In the meantime, you can workaround the problem by just positioning your mouse over one of the window borders and left-clicking (no need to drag or resize anything, just a single left-click). This triggers a window size change event and the window will be repositioned correctly.
Thanks for the bug report,
Richard Markievicz
thanks. I am aware of the workaround (although it helpful to the others that have it and dont know) but it sure would be awesome to have it properly.
thanks for fixing
Hello
Thank you for your patience. Wayk Now 2020.2.0 is now available for download, and contains a fix for this specific issue.
Please don't hesitate to respond again with further questions or feedback!
Thanks and kind regards,
Richard Markievicz
