Using session->disconnect does nothing.
This is just a small issue, but I was previously using Wayk Now 2020.1.3 and I've upgraded to the latest 2020.1.7
Since then, using session-> disconnect when in full screen mode does nothing. Though I can click the cross and the prompt to disconnect appears.
I'm using the same version on both the server and the client.
Hello
This is caused by a bug introduced in version 2020.1.4. We've identified the regression and a fix will be in the next release, I'll post back here once that's available.
Thanks for the bug report, and I apologise for the inconvenience
Richard Markievicz
Wonderful news. Actually, I'f like to point out that it's not the only option in the menu that does not work when in full screen.
Cheers.
Hello
Thank you for your patience. Wayk Now 2020.2.0 is now available for download, and contains a fix for this specific issue.
Please don't hesitate to respond again with further questions or feedback!
Thanks and kind regards,
Richard Markievicz
