DPS 2019.2.12 - No 2FA prompt in Edge
When trying to login to DPS via the web-login we are not getting any 2FA prompt when using Microsoft Edge browser.
Just gives a completely blank page.
All Comments (5)
Which Microsoft Edge browser are you using? Is it the latest chromium version?
Érica Poirier
It was the Microsoft Edge Legacy, so its a non-critical issue.
Thank you for your feedback.
The DWL companion tool haven't been updated for the Microsoft Edge Legacy for a while. That is the reason why it's not working properly with the latest DPS version 2019.2.12. We are only updating the DWL tool for Edge Chromium.
You will find the latest DWL versions for the most common browsers on the following page.
https://devolutions.net/web-login
Érica Poirier
Hello Erica,
its not the DWL thats the problem, its logging in to DPS.
First you enter you credentials and then you're suppose to get sent to Google Authentication page, but its completely blank.
For Microsoft Edge Legacy, Internet Explorer 11 and it has happened sometimes in Google Chrome.
Nothing in IIS logs or DPS logs.
Thank you for the information.
I will ask our QA team to test this behaviour and will get back to you next week on that matter.
Érica Poirier
