We would like to be able to configure what additional fields are automatically captured as part of storing a password for a site. This configuration option should be set at the master hub level so it applies to all users.
For example, we would configure https://access.paylocity.com/ to also capture the field CompanyID. Then when a user logs in to the webpage and Password Hub prompts to save the username and password, it would also capture the CompanyID and add it to the website in the hub.
Hi Carl,
I’ve added to our backlog your idea about having website templates with predefined fields. Meanwhile, you could create a template vault with template entries. With the right access, your users would be able to copy any given entry from that vault to the desired vault and set specific values in the copied entry.
Have a good day!
Maxime Morin
