discover the powershell commands and try to get the list of the first level folders. Example, the structure is:
A
A\AAA
A\AAA\AAAA
B
B\BBB
C
D
D\DDD
I would like to recover in powershell the list of folder:A
B
C
DCan you help me please ?
Thanks
Best regards
There are multiple ways to get first level folders using the PowerShell cmdlets. Here’s two ways:
1. Explanation: When the name and the group is same thing it means that the folder doesn’t have parents and thus is the first level folder
Get-RDMSession | Where-Object {$_.ConnectionType -eq "Group" -and $_.Name -eq $_.Group}
OR
2. Explanation: When the group doesn’t contain “\” it means that the folder doesn’t have parents and thus is a first level folder
Get-RDMSession | Where-Object {$_.ConnectionType -eq "Group" -and $_.Group -inotmatch “\”}
Olivier Désalliers
thank you for your return, it works very well
Best Regards
