I can ping it from my iPad just fine. I am connecting from iPad to laptop. If I choose to connect by prompt, I can see the prompt show up on the laptop. I can choose Accept. But the iPad app goes back to the home screen for Wayknow. And of course if I choose the secure password method, I can key in the password (which is showing on the laptop!) and it does the same thing. This was working a week ago.
Hi
That is really strange indeed. Can you provide us with the log file from your iPad?
In Wayk Now, open the settings (in the top-left corner) and change the "Logging level" to "Debug". Close the settings screen (by pressing "Done"). The setting won't take effect until the app is restarted - the easiest way to ensure that happens is to restart your iPad.
Now try your connection again. If the problem still happens, go back into the Settings and press "View Log". You should be able to select the text and copy it. You can send it to me via a PM.
(Incidentally, I realize posting this that it is not straightforward to share the log file, and I will look at streamlining that in a future release)
Thanks,
Richard Markievicz
