Hello dear Support-Team,
we want to implement a new password management tool in our company scanplus GmbH and found out about the password server you are offering. We've already had a look at the features, but there are still some questions that were left unanswered. Those Questions are the following:
I hope you can answer our questions soon.
Best wishes,
Niklas Heine
First I need to apologize, I had typed a lengthy response, and I guess I didn't submit it.
Please see my answers within your questions
> Our front-end is a Single Page Application (SPA), its not plain html. We havent received reports of the scenario you describe.
> I suspect that it is not possible with the SPA. It is achievable with our thick client, Remote Desktop Manager (RDM). To my knowledge, it is not implemented at this time.
>we do have a rich Role Based Access Control. 80% of our community meet with 20% of the complexity. If you delve in the deeper scenario, the learning curve can be quite steep.
> This is controlled by the lifetime setting of the security token. Its configurable.
>Last man wins, but we do have a mandatory refresh upon starting the edit mode. We also have full versioning info, so no data can ever be lost.
>we support their csv, as well as psafe3 format.
>this is a feature of our front-ends. On the other hand, we've just started on a Command Line Interface (CLI), I could imagine adding this feature.
>We've elected to make private vault really private, no other admins can see any private vault. Its a differentiating factor with our competitors. If you want a vault that is "mostly" private, you can disable the private vaults at the system level, and create vaults for each individual.
>not at this time, but its coming in a few sprints.
>we do have a checkout process and an extensive notification system. We do want to add a formal "interactive" approval workflow in the near future.
We can have a call if you need further info.
Again, sorry about the delay.
Maurice
thank you for your extensive answer.
We still have a few further questions that came up, since this post was made.
We also need some more information on the handling of brute-force attacks, especially when it comes to customization of the handling.
I hope you can answer those questions as well.
Best wishes,
Niklas Heine
I must ask, why arent you imposing the use of the password generator? Many of your questions on the "Distance" point to personal passwords rather than managed/service accounts.
I hate to use the tag line of a competitor, but the last password you should ever learn by heart is the one that gives you access to your password vault.
That editorial part being said, we have reports on complexity and age, an optional number of passwords kept in history that are forbidden to use, a list of forbidden passwords, but nothing in the category of "distance".
>we have a setting, and a quick access button in the status bar to prevent that.
>I would need more details, is a mandatory checkout sufficient for you? In our clients we have statuses, but that is not exposed in our SDK
>available, but not mandatory
Maurice
secure passwords are a high priority to us, but some old passwords do not follow our password policies and instead of going through every single one of them we want to see, if a password doesnt comply to our ruleset.
I agree that "distance" is off in terms of wording, but what you are offering in regards to password-quality seems like it meets our goals.
About the warning of users accessing sensitive data, it would be an optional feature to have our users be notified through a pop-up, that tells them that they are about to access sensitive data. Another option would be, that when a user wants to access sensitive data, he needs to give a reason for that.
And another question, can we customize the handling of brute-force attacks?
Niklas Heine
when are we supposed to get an answer for the remaining questions?
Niklas Heine
"Password quality meets our goals"
>good
Warning/notification
>as stated above, we have a checkout feature in which you must document a reason. Isnt that sufficient?
Customize handling of brute force attacks
> sadly no
Maurice
thank you for your answers, we have everything we need for now. If we need further information we contact you.
We will get in contact if our choice falls on your product.
Niklas Heine
we recently stumbled over another crucial feature, we would need, if we decide to go for your product.
That feature we need, is a way to change access permissions through the SDK/API. It would make a huge difference, if you'd offer such a feature.
If you don't offer this, is there another way to automize the migration of access permissions?
Niklas Heine
We do have a python SDK that would allow for this, but support is provided solely by the engineer in charge at this time. We have started on a Command Line Interface, but security management features are planned far on the future.
Maurice
Hello again,
Your product made it into the next round of evaluation. For that reason, I need some Information about
How can we achieve high-availability? Can we make redundant systems? Does it work in a master-slave configuration? How do we backup our data? What happens when we need to recover it?
What type of encryption do you use? How can the communication between client and server be safe?
Best Wishes,
Niklas Heine
As per https://helpserver.devolutions.net/gettingstarted_topologies.htm , you have multiple choices.
Those in our community that need a HA setup typically have two web servers (maybe a load balancer in front, there are good free solutions), and rely on a good DB backup strategy, or use SQL Azure in a GEO-redundant setup.
The questions are simple:
Those two questions drive all of your decisions. A "six nines" (99.9999%) uptime system is orders of magnitude more expensive to maintain than a "four nines" (99.99%) system.
At this time, you cannot have an active-active system, mostly because of our logging layer (we will improve that in the coming year).
And for encryption, the DB content is protected at rest by a unique encryption key generated on the server. You have to deploy a SSL certificate to ensure protection during transport, both on IIS and SQL Server.
Maurice
