I am evaluating Wayk Now as a possible replacement for Teamviewer
When I run the app, it does not connect to the den. I have to go to connectivity in preferences and disable the den, apply the change, then go back and re-enable the den and apply for the connection to happen. When I try to connect to my home PC, the connection happens, but as soon as I enter my password, Wayk Now crashes on the Mac, but continues to run on my home PC. I can connect to my home PC from my phone, so the problem appears to indeed be on the Mac at work.
My Mac at work does have 2 network connections. one to our general LAN and internet and one to our dedicated media SAN (no internet).
Could the double network possibly be causing the problem?
Hello Bern
Thanks for the report. So it seems like there are two separate issues, and maybe they are related (and maybe related to your dual connections).
To start, if I can grab a couple of details that would really help.
- I assume that you are using the latest version (2.1.1)? You can confirm that in the Wayk Now menu > About Wayk Now
- It would be really helpful to see the crash report from your Mac. If you open console.app, application crash reports are listed under "User reports". You should find one or more with the name starting "WaykNow...". You can right-click > Reveal in Finder and send me the file(s) either here in the forum or via PM. That would be incredibly helpful!
Thanks,
Richard Markievicz
