Mirror SQL setup doesnt auto failover
KajLehtinen
Disabled
Hi!
We got our DVLS SQL Backend (SQL2017) setup with a synchronous mirror setup, so it autofailsover when it needs to. I've configured backup SQL server in DVLS settings, but it doesnt seem to get that, since DVLS gets a DB error everytime the DB has failed over to the mirror partner.
What do I need to check/configure to get DVLS to understand/change automatically to the other mirrored instance?
/Kaj
All Comments (24)
Does your SQL instance manage the fail over or you have configured the fail over partner in the DVLS settings?
Have you only one DVLS instance or multiple instances connected on the SQL instance (HA/Load balancing topology)?
Érica Poirier
KajLehtinen
Disabled
Hi!
Its the SQL Server that automatically manages the failover to the mirrored partner & I've setup failover partner in DVLS settings.
Its only one instance of DVLS, dont think our license allows us to install a HA/Load balanced topology with DVLS - correct me if I'm wrong.
/Kaj
KajLehtinen
Disabled
We're using 4.7.0.0 on DVLS
First, I have looked in your records and you can indeed deploy DVLS in HA/Load balancing topology. If you plan to do so, please consult the following online help page about managing encryption keys in a HA/Load balancing topology.
Finally, because your SQL Server instance already manages the fail over, there is no need to set the fail over partner in the DVLS settings.
Érica Poirier
KajLehtinen
Disabled
Excellent - will put that into the todo itemlist.
Are you sure ? We're not talking Always on availability group, but a standard Synchronous Mirror. My understanding of the error that we have is that DVLS continues to talk to the 'mirror partner' server after a failover and since that DB isn't primary it doesnt answer. So I would assume that some sort of logic is needed in DVLS to retry the connection on the other configured DB.
/Kaj
After a discussion with an engineer, the connection pool still have the information of the server that failed and try to talk to it without success. We have on our to do list the implementation of such structure for testing. I will ask to set this on a higher priority.
Érica Poirier
KajLehtinen
Disabled
Thanks, can we get early release on this for us to test? Would hate to be forced to switch off mirroring on the DB and now it seems to swap mirror pairs every morning.
Sure, as soon as we get an internal version that includes a fix for this, I will send it to you.
Érica Poirier
KajLehtinen
Disabled
Below is the error from DVLS server when the DB fails over.
Error:
SqlException - A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server) at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection) at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection) at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection) at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) at System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry) at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry) at System.Data.SqlClient.SqlConnection.Open() at Devolutions.Server.DatabaseManager.GetDataSet(String sql, IEnumerable`1 parameters, CommandType commandType) at Devolutions.Server.DatabaseManager.GetData(String sql, IEnumerable`1 parameters) at Devolutions.Server.DataSourceManager.GetDataSourceSettingsDataTable() at Devolutions.Server.DataSourceManager.GetDataSourceSettings(SessionContext context) at Devolutions.Server.ServerManager.GetWebServerInfo(SessionContext context) at Devolutions.Server.ServerInfo.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) ------------------------------------------ Win32Exception - The network path was not found --- Default
Hi Kaj,
I had a chat with Erica and the engineering department and we will build a similar infrastructure as you to try to reproduce the same issue.
As simple Microsoft is many type of "Backup" exist in SQL server, some of them are: Always On HA, FailOver Cluster, Database Mirroring...
Is the Database mirroring that you talked about is this type of setup that Microsoft explain here (https://docs.microsoft.com/en-us/sql/database-engine/database-mirroring/database-mirroring-sql-server?view=sql-server-2017) ?
If so, to make it work as Microsoft write
Before a mirroring session can begin, the database owner or system administrator must create the mirror database, set up endpoints and logins, and, in some cases, create and set up certificates.
And I'm curious to understand how did you "copy" the information from the first database to the second database. Did you export and import all the entries? Did you backup and restore it. Do you have some idea about the initial setup because that could have a big impact of the setup.
I will wait your answer and base on these I will be able to go further in the setup or confirm the installation.
David Grandolfo
KajLehtinen
Disabled
Yes its that setup - we have it running in 'High-safety mode with automatic failover' I'e with a third Witness server.
We did according to the instructions from Microsoft, I'e make a backup of the database from the 'primary' server, then restore with norecovery and then switch on the Mirror on the mirror node and then finally on the primary node. The DB's then state that they are Principal, Syncronized on the primary and Synchronised, Restoring on the mirror. We've done the same setup on other DB's that support mirroring and they work perfectly over a fail over scenario.
Should we run a quick webex tonight to check that we haven't missed anything in the config? I'm available for another 2 hours or so. We've running 4.7.0.0 on the DVLS server itself.
Thanks for all these precious information.
With this setup I will build an internal Database Mirroring with three servers and test all this with Devolutions Server.
I inform you as soon as I give our engineering team the access to this setup.
David Grandolfo
KajLehtinen
Disabled
Any progress?
Hi Kaj,
The infrastructure for the test has been created and SQL server is currently configured. We had issues with the Windows and SQL licensing. Now everything is correct and we should transfer the servers to the engineering department next week the infrastructure to continue the case.
When the infrastructure is transferred to the engineering department, I will post on the forum to inform you of the progress.
David Grandolfo
KajLehtinen
Disabled
Is there any instruction on how to configure a loadbalancer in front of the two DVLS servers? Thinking specifically about KEMP Technologies.
I am afraid to say that we do not have any documentation about Kemp technologies configurations.
We haven't tested any Kemp products. It is quite impossible to test all different technologies available on market. DVLS should run on almost any load balancing topology as long as you set each DVLS instance that are connected on the same SQL instance to use the same encryption keys as stated on the following online help page.
https://helpserver.devolutions.net/kb_encryptionkeyha.htm
Érica Poirier
KajLehtinen
Disabled
Any progress on fixing the mirror failover scenario bug? We had a SQL server failover last night that forced the system into errorstate until I manually failed it back.
We are still working on this.
Regarding the issue you had last night, do you have any specific error in DVLS or Windows Event/ SQL event?
David Grandolfo
KajLehtinen
Disabled
Have you found the error and working on a fix or is it still that you are trying to identify the error?
Usually it fails over when we do a backup, but I'm on vacation this week so I just failed the DB back without anymore investigation.
/Kaj
We haven’t found the root of the issue yet. We are still trying to reproduce internally.
David Grandolfo
KajLehtinen
Disabled
Any news? We're on DVLS 4.0.7 and saw yesterday that it was quite old now. Any chance that if we upgrade that the error has sorted itself out?
I will get back to you after the Holidays as most employees are in vacation as well.
Happy Holidays!
Érica Poirier
KajLehtinen
Disabled
Just to follow up on this thread, it was a user error from our side that prevented the Mirroring from failing over - or DPS from working after a SQL DB failover occurred. It was as simple as that we hadn't added the user that the DPS server logs into the SQL Database with into the second SQL server.
When we added the user in question to the second MS SQL Server and tested to failover the DB it worked perfectly without hickups or anything in the DPS server / RDM client.
/Kaj
Thank you for your feedback and glad that you have resolv3ed your issue.
For the benefit of the community, could you please clarify the meaning of the DPS user? Is it the account set in the Application Pool Identity of the DPS web application?
Érica Poirier
