MS-SQL SSL Connection
skibba
Disabled
How can Connect to MS-SQL Server with SSL Connection? The Connection works only without SSL at the Moment.
All Comments (1)
It's not possible to connect on a SQL Server database with SSL from PVM Android because it's not supported by Mono, which is an application that is used in the development of PVM Mac, Android and iOS - http://www.mono-project.com/
When this will be supported, the integration will be possible.
Sorry about that.
